February 27, 20224 yr A friend of mine bought the clone and the settings are very limited if we compare it to other clones. It is fitted with the 450V MPPT and the model is TSP-VM11 5.5kW The inverter only has settings 01-14 as per the pictures below. We are trying to get to the following settings: 01 - SBU/SUB 12 - 50V 13 - 51V 16 - CSO or OSO 26 - 55V 27 - 54V 29 - 48V Any ideas would be appreciated.
February 27, 20224 yr 1 hour ago, Scorp007 said: We are trying to get to the following settings: 01 - SBU/SUB SBU = SBU, SUB = PAL Quote 12 - 50V 13 - 51V Setting 12 doesn't seem to exist on this model, which is pretty weird. Maybe it's a fixed offset from setting 14. Setting 14 on yours seems to be the equivalent of setting 13 on most Axperts, "back to battery" voltage. Quote 16 - CSO or OSO Again, doesn't seem to exist. Maybe it doesn't even support AC charging, and just PV charges whenever PV is available. Quote 26 - 55V 27 - 54V These are your settings 05 and 06 respectively. BTW, 55 and 54 are quite close together, which is unusual. What battery type? Quote 29 - 48V Setting 07 is the closest. Note: it seems to only set an alarm, not shut down the inverter. This clone seems to be worse than most, and that's saying a lot, I'm sorry to say.
February 27, 20224 yr Author 2 minutes ago, Coulomb said: SBU = SBU, SUB = PAL Setting 12 doesn't seem to exist on this model, which is pretty weird. Maybe it's a fixed offset from setting 14. Setting 14 on yours seems to be the equivalent of setting 13 on most Axperts, "back to battery" voltage. Again, doesn't seem to exist. Maybe it doesn't even support AC charging, and just PV charges whenever PV is available. These are your settings 05 and 06 respectively. BTW, 55 and 54 are quite close together, which is unusual. What battery type? Setting 07 is the closest. Note: it seems to only set an alarm, not shut down the inverter. This clone seems to be worse than most, and that's saying a lot, I'm sorry to say. Thanks a lot for the information. There is a setting 08 which is shutdown. I just did not put it on a picture as it explains itself. Sorry I made a mistake with the normal setting 26 and 27 as I used my own setting as I use on lithium. I did not record the settings I actually applied last week and they are for sure much wider. He is using flooded batteries. 4 x 100Ah which do not have enough capacity for his night time load. Yes it does use AC charging. I was trying to prevent him constantly charging and discharging the batteries during the night and wasting grid power. He seems to be using a lot more grid than his brother with similar panels and inverter. Also about the same daily consumption. Seeing this inverter settings I was shocked as I also bought from the same seller but my settings are spot on with the non clone accept for the price.
