Can I ad more batteries on 48V System with AGM Batteries
Hi all,
I´m a "newbie" when in comes to Solar & Batteries and here I am with my "whole set of questions":rolleyes::
( Apex 5KVA inverter, 12 x 235W Solarmodule, CEIL NXT Batteries 4 x 105AH running on 48V)
Output Ource priority :  @the moment:   Solar first
max charging                                        :  10 A
Battery Type                                         :  AGN
Max Utility Charging Current                : 10AH
point back to utility                                : 47V
back to battery mode                            : 49V
charger source priority                          : Solar only
bulk charging voltage                            :58V
floating charging voltage                       :54V
low DC cut off voltage                            :47V
are these values ok ?
do I have to buy the same sort of batteries to increase my storage capacity ?
can I easily add more capacity ( my batteries are 12 month old )
or must I buy a complete new set ?
1 hour ago, Chris Dononion said:
max charging                                        :  10 A
Rule says up to 15% of Ah capacity of battery, so you can bump these to 15A. The rest looks good to me (generically speaking), though ideally you should check the specification of the batteries.
Yes. Dissimilar strings are the death of batteries, be that age, capacity of chemistry.
It's not ideal. It can be done, by carefully monitoring both strings and making sure the old string still gets a full charge, at the expense of slightly overcharging the new string. It's complicated and I can almost confidently say that you're going to break both strings if you do that. Read this for more info.
Sell it on and get new 200Ah batteries if you can.
