April 14, 20224 yr Hey Guys, Starting my Solar journey soon. looking at installing pylontech 4.8kw battery 4x 390w solar panels to get me started and a luxpower sna 5000 off grid inverter with grid tied functions. I want to use this post as a bit of a journal. to get help along the way and hopefully help someone else looking to do the same thing. Got the solar panels today, waiting for the battery and inverter to be delivered. I bought 16 mounting clips; 12 roof tile hooks and 2x5m unistrusts. I think my first question is: is 6 roof tile hooks enough for a 5 meter span of unistrut guys?
April 14, 20224 yr 6 x roof tiles hooks will be enough. Below is what you are going to need to mount your panels -2 x Renusol Mounting rail 41 x 35 x 4400 mm -6 x Renusol Roof Hook Basic -6 x Renusol Mid Clamp -4 x Renusol End Clamp
April 16, 20224 yr On 2022/04/14 at 8:11 PM, hoohloc said: 6 x roof tiles hooks will be enough. Below is what you are going to need to mount your panels -2 x Renusol Mounting rail 41 x 35 x 4400 mm -6 x Renusol Roof Hook Basic -6 x Renusol Mid Clamp -4 x Renusol End Clamp The OP has already bought the mounting hardware including the unistrut channel rails as per the pictures posted. Why ditch it to get Renusol?
April 16, 20224 yr 4 minutes ago, Scorp007 said: The OP has already bought the mounting hardware including the unistrut channel rails as per the pictures posted. Why ditch it to get Renusol? Renusol is easy and straight forward to use. If he had just bought the hardware, I doubt the supplier will have a problem exchanging them
