BMS Connection for HOSelect Battery and Kodak Inverter
Hi Guys
Does anybody know which pins are used for the BMS Communication between a HoSelect Battery and Kodak Inverter as I am wanting to create the cable for them?
On the Kodak, the RS485 port should use pin 3 for RS485B and pin5 for RS485A. My Shoto and also Pylontech use pin1 for RS485B and pin2 for RS485A, you could try that to see if the hoselect battery uses the same standard, hopefully there is some kind of continuity amongst them. My new Kodak King came with a pylontech cable which works with the shoto.
