July 7, 20224 yr Hi All Hope you can help me, I have the following 5KVa Sunsync inverter, 10X 540W Panels and Hubble 5Kw Battery Please see atached pictures of comms, and error log in Home assistant Addon that i am getting. Currently the Brown is on B and Brown White is on A, we also tried Orange and Orange White. [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] done. [services.d] starting services [services.d] done. 2022-07-07 12:09:56,614 INFO Loading HASS OS configuration 2022-07-07 12:09:56,631 DEBUG could not patch umodbus: numpy not found 2022-07-07 12:09:56,636 INFO Filter *last used for battery_soc, total_battery_charge, total_battery_discharge, total_grid_export, total_grid_import, total_pv_power 2022-07-07 12:09:56,637 INFO Connecting to serial:///dev/ttyUSB0 2022-07-07 12:09:56,717 INFO ############################################################ 2022-07-07 12:09:56,718 INFO Inverter serial number 'XXMYSERIALNUMBERXX' 2022-07-07 12:09:56,718 INFO ############################################################ 2022-07-07 12:09:56,719 INFO MQTT: Connecting to mqtt_user@core-mosquitto:1883 2022-07-07 12:09:56,735 INFO MQTT: Connection successful 2022-07-07 12:09:57,848 ERROR Read Error: (1,78,1) CRC validation failed. 2022-07-07 12:09:57,849 INFO Retrying individual sensors: ['Total PV Power:last', 'Total Battery Charge:last', 'Total Battery Discharge:last', 'Total Grid Export:last', 'Total Grid Import:last', 'Battery SOC:last'] 2022-07-07 12:09:57,920 ERROR Read ErrorTotal PV Power: (1,96,2) CRC validation failed. 2022-07-07 12:09:57,989 ERROR Read ErrorTotal Battery Charge: (1,72,2) CRC validation failed. 2022-07-07 12:09:58,060 ERROR Read ErrorTotal Battery Discharge: (1,74,2) CRC validation failed. Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/sunsynk/sunsynk.py", line 52, in read_sensors r_r = await self.read_holding_registers(grp[0], glen) File "/usr/local/lib/python3.9/site-packages/sunsynk/usunsynk.py", line 43, in read_holding_registers return await self.client.read_holding_registers(self.server_id, start, length) File "/usr/local/lib/python3.9/site-packages/async_modbus/core.py", line 181, in read_holding_registers return await self._send_message(request) File "/usr/local/lib/python3.9/site-packages/async_modbus/core.py", line 142, in _send_message return await self.protocol._async_send_message( File "/usr/local/lib/python3.9/site-packages/async_modbus/core.py", line 78, in send_message_rtu return rtu.parse_response_adu(response_error_adu + response_remainder, adu) File "/usr/local/lib/python3.9/site-packages/umodbus/client/serial/rtu.py", line 183, in parse_response_adu validate_crc(resp_adu) File "/usr/local/lib/python3.9/site-packages/umodbus/client/serial/redundancy_check.py", line 76, in validate_crc raise CRCError('CRC validation failed.') umodbus.client.serial.redundancy_check.CRCError: CRC validation failed. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/src/app/./run.py", line 180, in read_sensors await asyncio.wait_for(SUNSYNK.read_sensors(sensors), OPT.timeout) File "/usr/local/lib/python3.9/asyncio/tasks.py", line 478, in wait_for return fut.result() File "/usr/local/lib/python3.9/site-packages/sunsynk/sunsynk.py", line 54, in read_sensors raise Exception( # pylint: disable=raise-missing-from Exception: (1,74,2) CRC validation failed. The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/src/app/./run.py", line 274, in <module> LOOP.run_until_complete(main(LOOP)) File "/usr/local/lib/python3.9/asyncio/base_events.py", line 642, in run_until_complete return future.result() File "/usr/src/app/./run.py", line 239, in main await read_sensors([f.sensor for f in SENSORS], retry_single=True) File "/usr/src/app/./run.py", line 197, in read_sensors await read_sensors([sen], msg=sen.name, retry_single=False) File "/usr/src/app/./run.py", line 191, in read_sensors raise Exception(f"Multiple Modbus read errors: {err}") from err Exception: Multiple Modbus read errors: (1,74,2) CRC validation failed. [cmd] ./run.py exited 1 [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] waiting for services. [s6-finish] sending all processes the TERM signal.
July 7, 20224 yr I know very little about HA, but the log says Bad Cyclic Redundancy Checks which suggests (90% chance) the physical layer. Ensure that you are using a twisted pair for the comms (Tx and Rx), and ensure that the twists aren't undone near the connector. They are essential for cancelling out crosstalk and other EMI.
July 7, 20224 yr There a specific need to use the physical connection? You could simply integrate your solarman into HA via WiFi.
July 7, 20224 yr 16 minutes ago, Marius Schonken said: How do you connect it via the WIFI? https://github.com/StephanJoubert/home_assistant_solarman
July 7, 20224 yr Author Thank you, just another question, does it work with SunSync dongle or just solarman dongle?
