July 8, 20224 yr Currently have a Sunsynk 5kw inverter, paired with 1 Hubble 5Kw battery. Trying to figure out whether my batteries are discharging too quickly. Refer attachments. At 18:00 SOC was 90%. Battery then more or less consistently discharged 0.35kW from 18:00 to 20:20. If I add in the 150w used by the inverter, it should result in 0.5kW being discharged. So in 2 hours, I'm expecting that only 1kW of battery power should have been used. The battery discharged from 90% to 24% though, which equates to +- 3kW. Is my math wrong? @HubbleLithium, I logged a ticket, but it was closed without providing any feedback, ticket #1686. Edited July 8, 20224 yr by Roy_ZA Adding system specs
July 10, 20224 yr Yes, the drop on SOC with virtually no load = you might have some damaged cells by the look of it. Do you have the Riot installed? Would be interesting what the state of health reports.
