July 25, 20224 yr Hi guys. Seems I've got the same issue with charge stuck on 90% This only happened once I added Pv arrange 4 days ago? Where is the best place to get the Rs232 cable and firmware, and user guides on how to upgrade? I've got, Sunsynk 5.5kw and 1 AM2 with 4.55kw pv array
July 25, 20224 yr Firmware etc you can get directly from Hubble. Cable, if nowhere else, solarassistant.io online shop.
July 25, 20224 yr Author 4 minutes ago, CyberJoe said: Firmware etc you can get directly from Hubble. Cable, if nowhere else, solarassistant.io online shop. Thanks how do I get from them, I'll try and log a ticket and see how far I get, How do I check firmware of battery?
July 26, 20224 yr Author 23 hours ago, CyberJoe said: Contact [email protected] for the files. Called, emailed, called emailed, zero replies, been reading their support is dismal by many many guys, this has got me thinking 🤔
August 2, 20224 yr i also want to update the firmware on my batteries. Has anyone got a RS 232 to RJ11 6 pin cable? I have the RS 232 to RJ12 but dont know the cable colours to make my own RJ11. Any suggestion?
August 8, 20224 yr On 2022/08/02 at 10:58 AM, ksg002 said: i also want to update the firmware on my batteries. Has anyone got a RS 232 to RJ11 6 pin cable? I have the RS 232 to RJ12 but dont know the cable colours to make my own RJ11. Any suggestion? Is an RJ12 not just a 6pin RJ11?
May 16, 20233 yr I also contacted the support telephonically for info and was promised firmware, app and a brief description of procedure, but am still waiting. I have now popped off and email and hope for better results.
May 16, 20233 yr I spoke to Khalid (Hubble) last year. He was most helpful. I also bought the cables from them. Rather expensive.
July 12, 20233 yr On 2023/05/16 at 8:09 AM, TedVic said: I also contacted the support telephonically for info and was promised firmware, app and a brief description of procedure, but am still waiting. I have now popped off and email and hope for better results. If you have a copy of the firmware will you please send to me as well?
