September 1, 20224 yr Should I start to worry here ? Temp went around 42 degrees on on the Pack 4 on the BMS... cell temp seems ok... battery charges and discharges fine in tandem with the others , so it seems fine in terms of power. It has 35 cycles or so. Edited September 1, 20224 yr by Jaxone
September 1, 20224 yr From what I have seen from readings it's seems the ambient temp sensor is near the BMS balancing part of the PCB and goes up when the cells are balancing.
