ISOLAR-SM-IV-5.6KW Change in output voltage
2 hours ago, misiekgab said:
Hello, My problem is the inability to change the output voltage from 230v in the 08 program to 220v or 240v, maybe someone will advise something
Do you not have the option under setting 8?. Other similar inverters can be 220  230  240V
Under the 08 option I have a 220V 230V 240V selection, after changing the voltage to 220V I still have 230V set. I would change the software but I can't find newer versions anywhere.
Just a question. Why do you want it to be 220V. 230V is the local standard voltage and most things are rated @ 230V. We just tend to talk of 220V.
13 hours ago, misiekgab said:
will sending the command 0x50 0x4F 0x50 0x56 0x32 0x32 0x30 0x30 0x6D 0xC0 by realterm will not hurt this model easun sm4 5.6kw ??
If the EASun is a clone, it's impossible to know for certain unless someone tries it, but the chances of it hurting the inverter are vanishingly small.
Don't forget that  the power switch has to be off (which will remove power from the AC output).
  • 5 months later...
