Paralleling Sunsynk inverters
Other than needing the same firmware, are there any other requirements to parallel two 5kW Sunsynk inverters?
The price difference between the 5 kW and 8 kW inverter is significant, and I'm trying to determine if I can get away with buying one 5kw inverter now (mainly as backup power for loadshedding) and then, if needed, later on add a 2nd 5 kW inverter.
Is there a risk that say for example 2 years down the line the "new" 5 kW inverter is not compatible with the "older" 5 kW inverter, making it impossible to upgrade? Any other disadvantages of have 2x 5 kW inverters vs a 8 kW?
Advantage 1x 8kW: Higher Amp rating on MPPT
Advantage 2x 5kW: 2 additional MPPT, giving more flexibility regarding strings
I personally would start off with 1x 5kW and later add a 2nd when funds are available. I don't think that anytime soon you will face the situation that a 'new' 5kW model will be out that cannot be paralleled with the current one
Just make sure that you pull sufficient cables (especially for PV from inverter to roof) to cater for a later upgrade
Thanks.
Just checking will a 540 watt panel (like JA solar, attached) work with this inverter? The current seems to be around the max allowed (~13A), so it seems they should. Although some sites selling this inverter states it cannot use a panel more than 460 watt.
JAM72S30_525-550_MR_Global_EN_20200904A.pdf
21 minutes ago, Leonb said:
Thanks.
those should work - inverter will clip anything over 13A. You would be limited to about 8 panels though based on those panels' VOC
Agree with @mzezman - they will work with the Sunsynk
Depending on where you are, you might even get away with 9 in series. Maybe check the Victron MPPT calculator tool and also speak to your installer
