September 29, 20223 yr Hi guys, I'd like to replace the fan in my inverter, it's quite loud, can someone help me identify what this is, any recommendations on a replacement? Thanks for the input!! SPECS: Part Type Model Brand Size Length Width height voltage Power Wires FAN EE92251B1-000C-A99 SUNON 92 mm x 92 mm x 25 mm 92 mm 92 mm 25 mm 12V 2.0W 2 Edited September 29, 20223 yr by bloupotlood
September 29, 20223 yr Replace with this: https://www.digikey.co.za/en/products/detail/sunon-fans/EE92251B1-000U-A99/2037307 🤪 But seriously, sunon make very good fans, you will be hard-pressed to find one that moves the same amount of air and is quieter. You could look at their more expensive ranges, which are slightly quieter and sometimes have a more pleasing sound profile. Other than that you are going to have to compromise on how much air you move.
September 29, 20223 yr Author 15 minutes ago, P1000 said: Replace with this: https://www.digikey.co.za/en/products/detail/sunon-fans/EE92251B1-000U-A99/2037307 🤪 But seriously, sunon make very good fans, you will be hard-pressed to find one that moves the same amount of air and is quieter. You could look at their more expensive ranges, which are slightly quieter and sometimes have a more pleasing sound profile. Other than that you are going to have to compromise on how much air you move. LOL, okay fine! I see mine has the 000C, these are the 000U, that won't be an issue? I can just "drop in" one of these? EDIT: Never mind I see C is for China office and U is for MURICA office. Edited September 29, 20223 yr by bloupotlood
