KMS inverter constantly charges my batteries every 10 min with 1 amp. Is that normal?
KMS inverter constantly charges my batteries every 10 min with 1 amp. Is that normal? only running this as a backup when loadshedding hits.
KMS 5kw inverter + 2 Hubble 5.5kw batteries. Float v =53.6 and bulk also 53.6
Well, the only thing that would make sense is that the inverter is using the battery to provide power. Once the voltage has dropped a little, it will use utility to charge the battery back up. How have you set your priorities?
I assume that you are using a battery type other than USE, suitable for talking to the Hubble battery's BMS via RS-485 or CAN bus, is that correct?
I'm not familiar with talking to BMS like this, but I do seem to recall that something similar happened with Pylontechs.
