November 27, 20223 yr My question is I have 4lithium battery solar wise 48v 120Ah to be connect to 12kva deye inverter 3phase can connect the battery in series or parallel please I need you help
November 27, 20223 yr If you have to ask this question, please find a professional to do the installation, it will be much cheaper that way!
November 27, 20223 yr Can only be parallel. In parallel the Voltage is the same, amps increase. If you connect in series you increase the voltage which will make your installation no longer 48V but much higher & you will damage the inverter. Rather get assistance if you can. The 12kW Deye is not a cheap specimen to damage.
