12V Lithium battery recommendations
Looking for a alternative to the normal AGM/LA 12V battery that can work with a 12V inverter.
Brands I have been researching:
Hubble S-200
Revov 12V 200Ah
Mecer 12V 200Ah
Any experience and other recommendations
Hubble S-200
Revov 12V 200Ah
Mecer 12V 200Ah
I have some Mecer 200Ah's. Also 2 S-100's. Both doing well but in use I feel the S-100's can provide more current for starting fridges. Just my feeling based on voltage sag difference between the 2.
3 hours ago, schalkvstaden said:
What inverter would you then recommend to use for a small fridge,small tv and one light?
I will ask people using a specific inverter. The 1.2kW Axpert with a 2x short term capacity will work. I have heard that the 0.8kW Victron does work but that's about the only below 1kW that I know of. Years ago I had a 0.6kW brick inverter that worked sometimes.
The Changi/Topshak in 3kW labelled that is a 1.5kW full time rating works very well. That is the one I used as indicated in the other topic. It can start any fridge no matter if it is a large fridge. Another major plus is this inverter has no fan running below 300W load and also has a display that shows AC and DC volts and Watts to the load.
The last year these inverters went up a lot in price that without having a charger makes them expensive compared to say the 1.2kW Axpert that includes a charger as well as PV input.
