Battery fuse to use
Depends what battery cable you use. The fuse is to protect the cable and can be used to protect the device.
35mm general welding cable cable AFAIK can carry 220Amps continuously.
It's a challenge to get the spec sheet from the supplier to see what it can do and what exact cable you getting but best is to try get the spec sheet of the exact cable they carry.
https://www.solar-shop.co.za/battery-cables/766-sunsynk-battery-cable-set-type-1-for-1065kw-battery-to-inverter.html
Going to use this cable. It is 50mm2
