Pylontech and Revov compatibility in one system??
Following a recommendation, I want to increase my Pylontech US 3000 3.5 kw/h capacity to 8.7kw/h with a Revov 5.2Kw/h
Manufactures do not want you to mix batteries, I believed this was for their commercial benefit. BUT!!
  • I see the float charge (Revov 54.5 V) (Pylontech 51.8-52V)
  • Bulk charge (Revov 55.5 V)(Pylontech 52.5 V)
  • Low voltage disconnect (Revov 49V) (Pylontech 44.5 V)
As I understand the upper and lower levels of charging and dis-charging are critical in the life expectancy of batteries
Do you think the two batteries can be effectively combined?
Thank you for your time!!
Greenbum
