Daxtronm BGH-5KW (Voltronic Infinisolar V2 Clone)
Hello to all hardware hackers and software reversers from this forum.
In the rush for cheap inverters, I bought a clone inverter of the Infinisolar V2 Daxtronm BGH-5KW. (looks exactly like Easun SV2 (Infinisolar V2) - a model very popular now in my country.
The only difference / problem that I noticed is that it does not work without batteries connected. If I have only AC IN connected, as soon as I turn ON the  AC out from the power switch it shows error 09 - bus soft start failed. It does not go into bypass mode.
I had a look on the schematic diagram (many thanks @Coulomb- great work there), i also did a side by side comparison with EASUN SV2 (Infinisolar V2) and I noticed that U11 is missing from the Daxtronm PCB board (please see 4th photo).
I also noticed that on the EASUN SV2 when in bypass mode, voltage on PV input (no PV's connected) rises to ~41...48[V] and on Daxtronm is only to 10...12[V]
Any ideas how to make it work without batteries? (like EASUN SV2 does?) Could this missing U11 be the issue?
Any thoughts/ideas would be greatly appreciated!
Main DSP is TMS 320F2809P7A, FW ver: U1 52 20.
Perhaps. I've never noticed that AC_ON input in any firmware, but then I've never had a need to find it.
Looks like you'll need a through-hole U6 as well, unless there is an SMD U6 under the board. This seems like penny pinching in the extreme. Or perhaps chip shortage in the extreme.
  • 2 years later...
after more inspection(repair) of other inverters, I noticed that the mainboard is actually from an offgrid inverter, this is why it is missing the U6. However, it works good and is reliable for 2 years now.
