January 9, 20233 yr Hi all On the Screen 3 of battery settings, there are four items: Lithium Mode 00 Shutdown 20% Low Batt 35% Restart 50% I have read the manual and still do not understand what the "Reset" setting is for. The DEYE manual suggests the above for Hubble Lithium Batteries. Can someone explain further the Reset setting, and can it be changed from the suggested value? Many thanks.
January 9, 20233 yr This post was recognized by Energy-Jason! mzezman was awarded the badge 'Helpful' and 50 points. 4 hours ago, Rello said: Hi all On the Screen 3 of battery settings, there are four items: Lithium Mode 00 Shutdown 20% Low Batt 35% Restart 50% I have read the manual and still do not understand what the "Reset" setting is for. The DEYE manual suggests the above for Hubble Lithium Batteries. Can someone explain further the Reset setting, and can it be changed from the suggested value? Many thanks. The battery settings work in this manner. Assume there is no Grid and no PV - so at night. The battery will be used until it gets to the 35% at which point it will shout and say i am on low battery. It will continue being used until the shutdown level (20%) and then it shuts off. The next morning PV comes online and charges the battery until 50% then the battery will start discharging again. I used PV in this example but it can be grid as well. You can change those settings to whatever is recommended by the battery manufacturer or what you are comfortable with - my settings are Shutdown - 10 Low Batt - 12 Restart - 15
