January 25, 20233 yr Esener 25.6V 100Ah Lifepo4 Battery https://www.esener.co.za/esener100ah.html Like new. R12500 Edited January 30, 20233 yr by jlr Price adjusted
January 30, 20233 yr Author I changed it, i bought it as new "secondhand", I have two, one is sealed in box. The other opened box. I tested the open box one and really nice batteries it seems. The terms need an original invoice, I do not have that. https://www.esener.co.za/terms.html importers Still think they are worth the money, That said I dropped the price. ANY tests welcome. I can connect them to a 3kW inverter. Thank you for understanding and be considerate for my dilemma. Warranty Conditions The warranty conditions apply only to products under warranty and include all defects of design, components and manufacturing. The following will not be covered by the warranty: Breaking the product seal (opening the casing) without proper approval Transport damage Incorrect installation or commissioning ( of programming) Failure to observe the user manual, the installation guide, and the maintenance regulations Unauthorized Modifications, changes, or attempted repairs Incorrect use or inappropriate operation Insufficient ventilation of the device Failure to observe the applicable safety regulations Force majeure (e.g. lightning, over-voltage, storm, fire) Warranty claim If a device becomes defective during the agreed time factory warranty period and provided that it will not be impossible or unreasonable, the device will be: repaired by the suppliers. Customers will be required to produce proof of qualified installer. Customers may be required to provide the original purchasing & installation invoice. E.S. Energy may refuse to Energy service if customers fails to provide the conditions above. The item will be sent for repair and may take up to 3 weeks. Battery Warranty For the battery you purchased (only applicable batteries), you receive a factory warranty valid for 1 year from the date of purchase and no more than one year from the purchase date by E.S.Energy. The battery need to be installed by a qualified COC electrician that specialises in solar and a certificate is needed. Any warranty claim will be null and void if any one of the following conditions were/are applicable: The Battery was not used for its intended purpose The Battery failure was due to abuse or neglect Draining the battery to maximum capacity and damaging the battery Damaged during courier transport Exceeding 50 percent dept of discharged (Or any other suppliers' recommendation applicable) If the battery has any other visible external abuse Should a warranty claim be accepted and the battery is replaced, the new battery will only carry a warranty for the remaining period of the original proof of purchase as per the claims procedure. Once the Battery has been returned, a representative will inspect the product, inspection results will determine whether the product is in fact defective and has in fact malfunctioned or failed/send it for laboratory inspection. Proof of payment is required. This i Edited January 30, 20233 yr by jlr
