February 1, 20233 yr I have the older type Axpert inverter 5KVA/4KW connected to Solar Assistant via the USB -B connector Using gel batteries currently. I want to upgrade to a Hubble AM2 battery. Can the BMS of the Hubble be connected to the solar assistant to get full comms or do I need a Hubble cloud link to achieve comms?
February 1, 20233 yr You can link via Voltage Mode USR to the inverter,and connect the battery to Solar Assistant for more stats yes
February 1, 20233 yr This is the cable to connect the AM2 to the Pi. https://solar-assistant.io/shop/products/hubble_am
