Pylontech differnce "Total Coulomb" and "Real Coulomb "
Dear all ,
Can someone explain to me the difference between "Total Coulomb" and "Real Coulomb " when I issue the pwr command on pylontech battery. See below
PYTES_debug>pwr 1
 Power  1
 Voltage         : 56579       mV
 Current         : -272        mA
 Temperature     : 35000       mC
 Coulomb         : 100         %
 Total Coulomb   : 100000      mAH
 Real Coulomb    : 99900       mAH
 Max Voltage     : 58000       mV
 Charge Times    : 5379
 Basic Status    : Dischg
 Discharge Sec.  : 38      s
 Volt Status     : Normal
 Current Status  : Normal
 Tmpr. Status    : Normal
 Coul. Status    : Normal
 Soh. Status     : Normal
 Heater Status   : OFF
 Protect ENA     : BOV BHV BLV BUV POV PHV PLV PUV CBOT CBHT CBLT CBUT DBOT DBHT DBLT DBUT POT PHT PLT PUT COC COC2 COCA DOCA DOC DOC2 SC LCOUL
 Bat Events      : 0x0
 Power Events    : 0x0
 System Fault    : 0x0
Command completed successfully
These two used to be equivalent "100000  mAH" but today I noticed a difference between the two and I do not know why or what is the difference.
Tnx
I have 6 batteries and they are all showing this. These batteries are only 1 month in use.
Is this normal?
Edited by Screech
