February 17, 20233 yr Hi and thanks for your advice. 4 x 12V 180AH lead acid batteries in series Floating Volts set to 54.3V BUT, after load shedding, it charges to 54.3V but then gradually drops to 52.2V and remains there. It also shows that battery voltage is going out. Why is that? Thanks. Deon
February 17, 20233 yr 41 minutes ago, deonholt said: Hi and thanks for your advice. 4 x 12V 180AH lead acid batteries in series Floating Volts set to 54.3V BUT, after load shedding, it charges to 54.3V but then gradually drops to 52.2V and remains there. It also shows that battery voltage is going out. Why is that? Thanks. Deon During charging the 54.3V is spot on. A lead acid that is fully charged does show 51.2V and higher under no load and that is about the float level. No problem with your levels.
February 18, 20233 yr Author 14 hours ago, Scorp007 said: During charging the 54.3V is spot on. A lead acid that is fully charged does show 51.2V and higher under no load and that is about the float level. No problem with your levels. Thanks very much. I am learning everyday about this.
February 18, 20233 yr 1 hour ago, deonholt said: Thanks very much. I am learning everyday about this. It's a pleasure. Feel free to ask as there is a lot of knowledge amongst the members. We learn everyday from each other.
