March 3, 20233 yr Good morning Newbie needing some help please. Installed a Sunsynk inverter and 2 x 5kW Sunsynk batteries two weeks ago. Since yesterday the slave battery's alarm light is on. Seems to be working fine during loadshedding, but returns to alarm state afterwards. Installer took me through a shut down sequence for the inverter, but soon afterwards the alarm light was on again. I was asked to shutdown again, but also compeltey switch off the batteries and then the battery fuse box. My question is, I can't seem to switch off the batteries completely. I hold the on/off switch for 3 seconds or more (even 30 seconds) but it just seems to reset and restart. Is there a way to completely shut off with no active lights on display? Have searched the web, but very limited information available, TIA 🙏
March 3, 20233 yr Author Figured it out, there is a rocker on/off switch beneath the cover. Did a switch off sequence, alarm light gone. Hopefully it solves the issue.
March 3, 20233 yr Author 😩 it did not work, alarm button on again. What I did notice is that the batteries are showing 100% SOC, previously only went to 99% SOC.
March 9, 20233 yr Hi there, did you manage to resolve this proble? I have the same issue this morning, after the system running okay for two weeks.
March 9, 20233 yr Author 10 hours ago, DuncanV said: Hi there, did you manage to resolve this proble? I have the same issue this morning, after the system running okay for two weeks. Yes, my installer spoke to Sunsynk and they recommended a firmware upgrade to the batteries. Was done this morning and so far so good, no alarm light 🤞
March 23, 20233 yr On 2023/03/09 at 5:52 PM, SiriS said: Yes, my installer spoke to Sunsynk and they recommended a firmware upgrade to the batteries. Was done this morning and so far so good, no alarm light 🤞 Is it still OK? Mine does exactly the same
March 27, 20233 yr Author On 2023/03/23 at 4:23 PM, Virwat said: Is it still OK? Mine does exactly the same Hi no issues after the firmware upgrade.
April 2, 20233 yr Does anyone still have access to the above document? My battery is not powering on and keeps on flashing the alarm light at me! Cheers!
September 8, 20232 yr Please advise where can I find the firmware update and how to run the update into the system? Thanks
