March 4, 20233 yr Good afternoon. Axpert VM III 5000 firmware DSP47.00 and MCU2.61. There is a problem setting the SBU mode, in menu item 12 you cannot set more than 51v, is there a way to increase this value to 55-57v. This inverter is sold under a different brand and there is a value of 44-57. Are these values stored in the DSP or MCU? Will updating MCU to 2.81 fix my problem?
March 4, 20233 yr 9 minutes ago, risen said: Good afternoon. Axpert VM III 5000 firmware DSP47.00 and MCU2.61. There is a problem setting the SBU mode, in menu item 12 you cannot set more than 51v, is there a way to increase this value to 55-57v. This inverter is sold under a different brand and there is a value of 44-57. Are these values stored in the DSP or MCU? Will updating MCU to 2.81 fix my problem? Not offering an answer for the problem but the normal setting range for these inverters is 44-51V as you have found. Designed with lead acid in mind where 51V is a high level to switch to grid during discharge.
March 4, 20233 yr Author I assembled assembly 14S Li-ion LG E63 and it is desirable to set a higher value for them
March 5, 20233 yr 9 hours ago, risen said: in menu item 12 you cannot set more than 51v, is there a way to increase this value to 55-57v There are 64 V models and 58.4 V models. In 64 V models, you can go to 57 V. I'm a bit surprised that your VM III is limited to 51 V. I myself run patched firmware that allows me to go to 58 V. But it's quite a lot of work. You may need to exchange your inverter for one that has the 64 V max charge voltage, which will also have the higher setting 12 maximum setting voltage. 10 hours ago, risen said: Are these values stored in the DSP or MCU? Will updating MCU to 2.81 fix my problem? They are stored in the DSP as well as the MCU, I believe. I very much doubt that updating to 02.81 by itself will fix the problem. Sorry I haven't got better news.
March 5, 20233 yr Author In paragraph 26, the maximum charging voltage is 61v. At point 5 there are many different types of batteries, including LIB. He knows how to work with lithium, but it is impossible to set up the correct operation.I'm thinking of flashing the DSP, but if it fails, I won't be able to return to my version, which is not freely available 47.00. Thanks for trying to help.
March 5, 20233 yr 50 minutes ago, risen said: In paragraph 26, the maximum charging voltage is 61v. Ah yes, some are 61.0 V instead of 58.4 V. But still not 64 V.
