March 12, 20233 yr Hi, I have installed some Eachen Smart Light switches, ( no neutral required ) models, install went pretty good. Only problem is my kitchen led down lights flicker. It's not switch related as I have another set of LED downloads doing the same. Supplied capacitor is installed across one led light per switch. Not sure if it's the LEDS I am using? ( lightworx GU10 3w warm white ) Any advise? Thanks, Kevin
March 14, 20233 yr Author So, if anyone else runs into this problem. I replaced the standard LED down lights with Osram LED dimmable ones. The flicker is now gone. All house lights switches are now Eachen, a real pleasure to use. Cheers, Kevin Edited March 14, 20233 yr by Kevin Lourens
