March 23, 20233 yr When using a single sunsynk inverter should it be set to master or slave? I noticed that by default it was on slave?
March 23, 20233 yr Slave is the default yes ,if you only have one inverter it does not matter to what it is set .
August 12, 20233 yr good morning all, I am a novice and do not understand what is the the purpose of the master-slave configuration
