Daxtromn Inverter Charger AGH-6.2KW - what is the voltronic equivalent?
Hello all, do you have any idea what would be the Voltronic equivalent for this inverter?
Did anybody test it? How does it work on the long run, Any known bugs in firmware/hardware?
https://daxtromn-power.com/products/6.2kw-hybrid-solar-inverter-pure-sine-wave-220vac-output-48vdc-input-120a-mppt-solar-charger-controller-6200w-european-union-stock-fast-ship?sku=18058548595162234918413742
6.2KW Hybrid Solar Inverter Pure Sine Wave 220VAC Output 48VDC Input 120A MPPT Solar Charger Controller 6200w European Union Stock  fast ship
Edited by sethmad
I don't think that there is a Voltronic equivalent; if there is, the closest would be one of the Infinisolar models. I don't know much about those.
It seems to be yet another new brand, so I doubt anyone would have any experience with it.
The display reminds me of a Growatt:
  • 1 year later...
I have also two of above invertor, it seems to blow out if grid tie exceeds 14ampere for 6200W. So i set it to 14 ampere equivalent to 3kw max export but in  specifications they mentions arround 48ampere for 6300w.
So it blew out the IGBTs when you put more than 3KW export to grid? That is good to know. Have you repaired it yourself?
