March 24, 20233 yr Hello all, do you have any idea what would be the Voltronic equivalent for this inverter? Did anybody test it? How does it work on the long run, Any known bugs in firmware/hardware? https://daxtromn-power.com/products/6.2kw-hybrid-solar-inverter-pure-sine-wave-220vac-output-48vdc-input-120a-mppt-solar-charger-controller-6200w-european-union-stock-fast-ship?sku=18058548595162234918413742 Edited March 24, 20233 yr by sethmad
March 25, 20233 yr 13 hours ago, sethmad said: do you have any idea what would be the Voltronic equivalent for this inverter? I don't think that there is a Voltronic equivalent; if there is, the closest would be one of the Infinisolar models. I don't know much about those. 13 hours ago, sethmad said: Any known bugs in firmware/hardware? It seems to be yet another new brand, so I doubt anyone would have any experience with it. The display reminds me of a Growatt:
May 24, 20233 yr I have two of these exact inverters running. Seems fine. Software is adequate but not great.
May 26, 20242 yr I have also two of above invertor, it seems to blow out if grid tie exceeds 14ampere for 6200W. So i set it to 14 ampere equivalent to 3kw max export but in specifications they mentions arround 48ampere for 6300w.
May 27, 20242 yr Author I did some more research and it seems that they are produced by https://www.nextpowersolar.com/ They are similar to voltronic but seems to be another design and production team. What do you guys think about this?
May 27, 20242 yr Author On 2024/05/26 at 10:11 PM, arif78 said: I have also two of above invertor, it seems to blow out if grid tie exceeds 14ampere for 6200W. So i set it to 14 ampere equivalent to 3kw max export but in specifications they mentions arround 48ampere for 6300w. So it blew out the IGBTs when you put more than 3KW export to grid? That is good to know. Have you repaired it yourself?
