April 14, 20233 yr Hi all Have been running a Kodak OG Plus 5.48 for an year odd with 2 x Kodak FL5.2 batteries Recently added two more of the same batteries. I now see BAT no 4 (only) display error "High Voltage Fault" from time to time [LED no 2 flashes with RED LED on] it will be on for a few minutes (+/- 5min), then off for a longer period (+/- 15min) - I have spent a week trying to call Segen support, could not manage to speak to anyone, ask for VM then cuts off, no action from the VM left Any insight / suggestions pls
March 14, 20242 yr Hi Smokey, Have you come right? I had to upgrade the old battery firmware when adding a new one. Edited March 14, 20242 yr by MJS found what I was looking for in an older version of the FL5.2 Manual
March 14, 20242 yr Author Afraid I couldn't figure out how to upgrade the battery's BMS. For some other reason (cant remember) I moved the controlling of the batteries from separate (one INV per 2 BAT's ) to 1 INV to 4 BAT's so the 2nd slave INV does not control the BAT's never had the issue again EDIT: I just remembered, after looking at my notes of the time ... the BAT config did not solve the problem, I still happens when I run in SUB mode, in SBU = no issue Edited March 15, 20242 yr by Smokey
