UNDERSTANDING A LITHIUM BATTERY DOD (Percentage)
Need Help.
I want to know how i culculate the lithium battery percentage or DOD. Hw do i know how many percentage i used during loadshading.
THIS MIGHT SEEMS UNRELATED
I am using a 3kva 24v growatt inverter paired with 25.6v ESENER lithium battery.
1. The inveter does not displays battery percentage only volts.
2. The lithium battery does not have the screen where you can see or monitor the battery percentage
For the above reasons, i am asking to be assisted to know or see how many percentage or DOD of the battery when in load.
I hope this will be clear, any assistance will be appreciated
15 hours ago, Furlongs said:
Need Help.
https://www.esener.co.za/esener100ah.html
Esener 25.6v 100Ah Lithium Battery
https://www.esener.co.za/esener100ah.pdf
Have a look at spec sheet, 0% Cut-Off / Shutdown Voltage: 20.0 V
100% Charged Voltage 29.2 V..
Specifications
  • Model: ES-25.6V 100Ah
  • Rated Capacity (5HR): 100Ah
  • Voltage: 25.6V
  • Discharge Cutoff Voltage: 20.0V
  • Equalised Charge Voltage: 29.2V
  • Maximum Continuous Charging Current: 100A
  • Maximum Continuous Discharging Current: 100A
