Help me choose
I am interested in getting the following setup:
Sunsynk/Deye - 5kW inverter
Revov R100 / Volta Stage 1 - 5kW batteries
Looking to get the Sunsynk with the Revov or the Deye with the Volta.
Apparently the official Deye importers (Africo Solar) are also the owners of the Volta battery brand. So if you pair them up you get extended 11 year warranty on the battery.
What I want to know is if it is really better to get the Sunsynk over the Deye and if the Volta battery is decent? (See battery brochure attached)
Are there any other battery brands which you wll recommend which are around R27k for a 5kW capacity.
Volta Stage 1.pdf
Well, if they are prepared to give an 11 year warranty, then what could go wrong except that you may have the inconvenience to have it fixed if it does give trouble within the 11 years.  By that time new battery technology would have superseded the current overpriced Lithium technology.
