Sunsynk Inverter configuration questions
  • Replies 53
  • Views 52.4k
  • suds7162
    suds7162
    Ok, so first a summary of my setup: 8 kW Sunsynk inverter 2 x 5kWh Greenrich WM5000 wall mount batteries 10 x 555W Longi panels, for a peak of 5.5kW nameplate capacity. Al
  • suds7162
    suds7162
    So in summary, on a normal day like today, with lots of sunshine: Some things to note: Not sure what that 01h00 spike is. Need to figure that one out.  The 04h30 geyser boost
  • Change around your CT coil wires in the inverter or install the CT coil the other way around as its not the right way.
  • 1 year later...
Hi HeinieV. You are the first person I have seen that has the same setting I have in MODE - SYSTEM2. IE: Like you I have a box labelled " EXPORT POWER LIMITER" , but everyone else ( other than you ) seem to have the box labelled as " INVERTER POWER LIMITER ". I bought my unit secondhand, and therefore did not get a manual. Every Sunsynk 8K model manual I have found and download has the " INVERTER POWER LIMITER " box. Mine is the SUBSYNK-8K-SG01LP1-EU . Could you please tell me exactly what model yours is ?, so I can hopefully download a manual that is exactly like my inverter. Thanks david
  • 11 months later...
Good day,
I have 16kw Deye Inverter, 2 x 16kwh Deye Batteries, 20 x 550w panels installed on our new build.
How do I maximise the set up(with assistance on the settings) to use minimum grid power.
The electrician did a great job with the physical installation but I seem not to winning on the settings side.....
Thanks in advance
