June 22, 201511 yr Just read through the Axpert Inverter Manual and noticed the following efficiency specs: 1) Solar Charging Mode: 98 % (max eff.) 2) Inverter Mode: 90 % (peak eff.) So i assume that if solar is supplying the load the max efficiency will be 88 %. A minimum 10 % of battery capacity is lost, just by inverting the battery voltage to AC power. I would like to know if anyone has an idea of the inverter efficiencies at different output power ratings.
June 24, 201511 yr The Imeon efficiency is in the order of 93-95%. The hybrid inverters are infinitely superior to the old linear PV -> Charge controller -> Batteries-> Inverter -> Load. You can use energy as you generate it. In the older system you had to store it first and suffer the inherent inefficiencies.
June 26, 201511 yr Author Hi Chris, looking at the Axpert line diagram it seems to be the old inefficient way of doing things. The solar PV input is converted down to the battery voltage and then inverted back up to 230 Vac. Would love to know what the efficiency of this inverter is at different load levels.
June 26, 201511 yr Hi Carl there is an Australian forum http://forums.aeva.asn.au/forums/forums.html. Some of the guys have taken their inverters apart, soldered in different resistors etc. They may well be able tell you more.
June 26, 201511 yr Author Thanks Chris will check it out. Would love to hear about your interesting installation and how the Axpert deals with farm life.
June 26, 201511 yr Plan to make a lot of progress this weekend. Perhaps have AC input and output and batteries wired up by Sunday.
July 3, 201511 yr Plan to make a lot of progress this weekend. Perhaps have AC input and output and batteries wired up by Sunday. Please, keep up posted!
July 4, 201511 yr Please, keep up posted! Look at my Fastening PVs post in Solar Beginners first pictures
September 22, 201510 yr Has anyone done some tests on this inverter to see how efficient it really is, both from a PV and batteries point of view? It would be interesting to see some charts. Unfortunately I don't have the equipment todo it myself.
