June 20, 20233 yr https://bslbatt.co.za/bsl-powerline-5/ Does anybody have data on this batteries...it comes on then all the battery lights are flashing and when you switch it off it shows a red fault light ... Thanks Dumb-Solar-Techie
June 20, 20233 yr 26 minutes ago, ronaldverweerdt said: https://bslbatt.co.za/bsl-powerline-5/ Does anybody have data on this batteries...it comes on then all the battery lights are flashing and when you switch it off it shows a red fault light ... Thanks Dumb-Solar-Techie Sounds like your battery is not charged. If all green led's are blinking the battery needs to charge. If one green led is solid on you have charged partially they all need to be solid on then battery is fully charged. Some details on inverter, comms cable, battery dip switch positions , charger settings. Post some pics.
June 20, 20233 yr Author Thanks for the reply ...We installed the same batteries to two Sunsynk 8kw invertors with the comms cables installed and all six batteries came up with 60% capacity. And communicate with the Invertor. The ones I'm talking about are for a Victron System with a cerbo-Gx controller ,three phase Victron Quatro system with two Victron MPPT's ...When we switch any off the batteries ON...the LED lights flash like a night rider bar ...and then when you switch the OFF the bottom LED stays in a Alarm status ...and you cannot switch the battery OFF anymore...
June 20, 20233 yr 3 minutes ago, RonaldVerweerdt said: Thanks for the reply ...We installed the same batteries to two Sunsynk 8kw invertors with the comms cables installed and all six batteries came up with 60% capacity. And communicate with the Invertor. The ones I'm talking about are for a Victron System with a cerbo-Gx controller ,three phase Victron Quatro system with two Victron MPPT's ...When we switch any off the batteries ON...the LED lights flash like a night rider bar ...and then when you switch the OFF the bottom LED stays in a Alarm status ...and you cannot switch the battery OFF anymore... Ok sounds intense this might help. https://www.victronenergy.com/live/battery_compatibility:bsl
June 21, 20233 yr @RonaldVerweerdt with the Victron Quattro's you will probably need to pre-charge the capacitors. The batteries are probably going into a fault mode due to the high in rush current. Have a read here for the explanation and how to do it -> How to pre-charge an inverter easily | Climbingvan
June 21, 20233 yr Author The Victron Quattro's are not even connected yet .....we trying to setup the Cerbo-GX to talk to the batteries for the BMS...
