WHAT IS THE EMS SOFTWARE TO USE WITH AXPERT KING INVERTER
Hello everyone,
I require to mintor an axpert king inverter (voltronic) with EMS, I have tried to get the type that could work with the inverter, no luck yet. I know quite well that gurus are here to get what it required. Please share with me if you know any. It will be appreciated. Thank you all in advance. Cheers
1 hour ago, razzor13bt said:
check out this software
This software requires pylontech battery and connection cable which I'm not using with the inverter. Is there any other suggestion 🙏?
