July 5, 20233 yr I was set on getting myself the 8kW Sunsynk and mitigating the fan noise by implementing @BrettB's silence hack . However, on the generous advice of Steve @ PF I am now considering the Solis S6 Pro 8kW as it will handle my Canadian 550w's better, and has faster turnaround times in the case of a warranty issue. It looks like it can meet my needs regarding setup, scheduling and interaction with home automation. Does anybody have experience with these, specifically around the fan noise? I have to install it in my passage so don't want it to be humming and whining in the middle of the night.
July 5, 20233 yr The S6Pro 5kW version has passive cooling. The S6 8kW has active cooling similar to the sunsynk so it has fans too and they will also ramp up with high/continuous loads. Have not installed one yet so no idea at which levels the fans ramp up or how loud they are.
July 5, 20233 yr 24 minutes ago, Richard B said: and has faster turnaround times in the case of a warranty issue They have good warranty stock and never fix faulty inverters, they swop them out direct from their warranty stock and send the faulty unit back to china to their r&d. Not many suppliers/brands do that Edited July 5, 20233 yr by WannabeSolarSparky
July 5, 20233 yr Author 28 minutes ago, WannabeSolarSparky said: The S6Pro 5kW version has passive cooling. The S6 8kW has active cooling similar to the sunsynk so it has fans too and they will also ramp up with high/continuous loads. Have not installed one yet so no idea at which levels the fans ramp up or how loud they are. This is what Steve said too, so if I really want the strong silent type I could go for 2x 5kW S6Pro's and it would work out to cost marginally more than an 8kW Sunsynk and be future proof.... hmmm...
July 5, 20233 yr 1 minute ago, Richard B said: would work out to cost marginally more than an 8kW effectively 10kW inverter And their capacity to do double rated load for short bursts would give you 20kW to start motors provided your wiring and breakers can handle it
September 13, 20233 yr Anyone installed this one yet? Also concerned about the fan noise levels. Did a Kodak 10KW and that one is quite loud, so looking for a more quieter inverter. On another topic, how would you guys say this inverter compares to Sunsynk?
