Voltronic Coms Protocol - QPGSn
Does anyone know if there is a command that replaces QPGSn on newer inverters? The command does not seem to work on Kodak OG-7.2 in parallel, which means I can't read the complete data set for PV Strings on any of the inverters.
Davo
As far as I know QPGS is still there.
What U1 and U2 (DSP and display) firmware are you using?
Weber and I recently discovered some wrinkles with the machine number parameter (the n of QPGSn), but that should be transparent if you use the usual RS-232 comms. In other words, unless you are talking directly to the DSP (bypassing the display), you should not notice anything different.
