Luxpower view app down?
3 hours ago, DeezGP said:
Hi all.
Just checking if anyone else cannot access the app today or is it just me?
Yeah, africa servers was uppy downy today. Actually been like that for a few weeks now.
6 hours ago, THULANE said:
I have noticed that mostly on Sundays afternoon it's down, comes back Monday afternoon. 🙈
I guess it does not work Sundays either
7 hours ago, PsyCLown said:
So this is a common issue with the Luxpowers?
I guess the alternative would be to use Solar Assistant instead? Although comes with an additional cost.
home asisstant and lxpBridge is free; just requires your time
I am been thinking about trying this first before forking out for Solar Assistant.
You using lxpbridge to pull info for automations?
Indeed. Wasn't too difficult. Install HA, install lxpbridge, install mosquitto. Configure
Is this on pc or can it be done on mobile?
Its quite common for Home Assistant to be run off a Raspberry Pi. Low power consumption and small form factor.
  • 3 months later...
On 2023/07/16 at 4:49 PM, DeezGP said:
Hi all.
my luxpower app is loading up but saying offline a friend said the app is down is anyone else having the sae proublem
I had experienced issues with either the app/servers being down or one or both of my inverters as showing offline.
However since I have setup Home Assistant with LXP Bridge I no longer experience these issues and I find myself using Home Assistant to check my inverter info more than I use the Luxpower app.
