July 22, 20232 yr I have a 3kw SRNE inverter. I purchased a datalogger to monitor via my cellphone. I have successfully configured the software but my datalogger shows offline. I have gone through the diagnostics and it succeeds however it still shows offline. Can anyone help.
July 22, 20232 yr This is a common problem with the datalogger. Its a directional logger and not omnidirectional. I would suggest that you point the logger in the direction of your modem and restart it. Give it about 5 minutes and that should solve your problem.
July 22, 20232 yr Author 1 minute ago, SolarDIY said: This is a common problem with the datalogger. Its a directional logger and not omnidirectional. I would suggest that you point the logger in the direction of your modem and restart it. Give it about 5 minutes and that should solve your problem. Thanks for the speedy response. I will try that immediately and report back.
July 22, 20232 yr Author 22 minutes ago, SolarDIY said: This is a common problem with the datalogger. Its a directional logger and not omnidirectional. I would suggest that you point the logger in the direction of your modem and restart it. Give it about 5 minutes and that should solve your problem. I cant believe that actually worked. Thanks a million. My logger is online and i can now see all the data.
July 22, 20232 yr 1 minute ago, Solarnubie said: I cant believe that actually worked. Thanks a million. My logger is online and i can now see all the data. You are welcome. Glad to be of assistance.
July 22, 20232 yr I see with their new software update the colour schemes are very dark. Is there anyway to change this as i find it difficult to read.
July 22, 20232 yr 1 minute ago, UltraSolar said: I see with their new software update the colour schemes are very dark. Is there anyway to change this as i find it difficult to read. Unfortunately there is no option in their current software to switch to a light theme. There are two solutions though. You can either uninstall the new version and download and install one of their previous versions or you can download tgpro which has the exact same interface as their older versions but just branded with another company name.
