SOL-I-AX-8M2 to Hubble AM-5 BMS interface
I have a Mercer SOL-I-AX-8M2 (8Kva) inverter and 3 x AM-5 (5 Kwh batteries).  Current batteries are configured in User mode with setting from Hubble website. The Mercer (Aexpert) Battery communications port has RS232, RS485 and CAN pins. However I am unable to establish communications between Master Battery and the  inverter.
Is anyone able to advise me whether there is a protocol converter available that will suport BMS communication between Hubble and Aexpert?
Thanks, I will follow the lead. It is strange that in my correspondence with Hubble (via their website) did not point me in that direction in stead the their response was:==>
"... there are two types of Mecer Inverters. You have true Axpert (Voltronic) and Soli Infini Type. Yours are the latter. The SOL-I-  which means it works best on USE instead of Li. Unfortunately, Cloudlink will not be necessary, because of the protocols. Unless you decide to change your Inverter.  Kind Regards..."
I think they're confused by the many variations of Axpert models via the different rebrandings. It's not hard, I have to admit.
I'm pretty sure that yours is a genuine Axpert Max made by Voltronic Power.
  • 8 months later...
