Clint
Hi there im running a 5kv mecer inverter wth a lifpro4 48v lithium battery no solo at tgis stage it is a simple install pls can you assist me on the battery settings for charge and dis charge etc it seens my my battery is over changing and when i reset the battery it works for 3 or 4 days and then makes a beeping noise reset again and so on
20 hours ago, clint versfeld said:
Hi there
Welcome to the forum.
It really helps us when you give us good details. I assume that you mean an LFP (LiFePO₄) battery, but we need to know if it's 15S or 16S. Can you give a model name? Or at least its nominal voltage; some say 51.2 V which is a clue that they are actually 16S. Or if it says anything about maximum charge voltage on the case or in any documentation or web page.
Supply your settings 05 12 13 26 27 and 29.
Also the label of the battery or the make and model.
