August 3, 20233 yr When it is 08:00 in South Africa my Deye 8Kw will display 09:00, which is annoying when you want to set "Time in Use". Does anyone have a clue how to fix this? I suspect the firmware is set to GMT +3 which is for East Africa. Please help.
August 3, 20233 yr You are correct that the time zone your inverter / dongle is set to is an hour ahead.
August 3, 20233 yr 52 minutes ago, klaushan said: When it is 08:00 in South Africa my Deye 8Kw will display 09:00, which is annoying when you want to set "Time in Use". Does anyone have a clue how to fix this? I suspect the firmware is set to GMT +3 which is for East Africa. Please help. Ensure you use GMT +2 for a zone that does not have daylight saving. ZA Pretoria/Zim Harare but not Cairo as I was told they introduced daylight saving. @zsde will be able to help us out. Edited August 3, 20233 yr by Scorp007
August 3, 20233 yr 29 minutes ago, Scorp007 said: Cairo as I was told they introduced daylight saving Egypt did introduce Daylight Savings time as per the dates in the table below. Last Friday in April at 0:00 Last Thursday in October at 24:00
August 3, 20233 yr I wonder if or when Western Cape will introduce DST? Good to know that Egypt have introduced it, I use to select Cairo at GMT +2 at times.
