3kw inverter to DB connection
Not an electrician nor claim to be an electrical expert. Just a diy'er who would like some insight as I am considering mounting my inverter setup to the DB.
Very small household, work from home full time, need internet, laptop, screen, maybe a light or fan in the evenings during load shedding.
Equipment:
Requirements:
  • 2x socket CB's and 1x Lights CB to run on inverter/backup system connected to DB
Notes:
  • There is the neutral bar connected straight to Eskom which feeds stove, geyser and lights. (Lights run off neutral bar 1 - Eskom)
  • I am planning to run lights on my inverter, so I guess I will have to get an electrician to trace the neutral wires to the lights and run them from neutral bar 2 running from E/L?
  • AC box out will feed to neutral bar 2 on main DB. Will this be an issue as there are then 2x E/L running on neutral bar 2? If so, how do I mitigate this?
  • I do not want to run all plugs and lights as essentials as the inverter is only 3kw. Concerned that I accidently  switch on the dishwasher and the kettle, then damaging the inverter
  • 32A AC CB as that is what is recommended on inverter manual
  • 13A AC CB on output as the inverter is only 3,000w
  • I do have 125A DC fuse disconnectors for the battery
  • The inverter and battery will both be grounded by earth coming from Eskom
Please let me know your thoughts. Am I on the right path here?
Equipment:
Requirements:
Notes:
32A and 13A CB can both be 16A as the closest to the inverter output.
Cannot see any reason why the 32A is such a high rating.
I suggest you get someone to check what should be done in the DB.
Equipment:
Requirements:
Notes:
You need changeover switch to bypassing the inverter in case of a failure.
