Axpert 4Kw Settings and error.
I am new to the blog but have seen many discussions on Axpert settings.
I need advice on my system please.
2 x 4Kw Axpert (One is RCT and the other Mecer) Connected parallel.
18 x 260 w panels connected to both inverters. +_ 4.5kw
8 x Narada 12NDT200 AGM batteries. 200A each. Float charge - 54V . Bulk charge 57.6V.
Settings at this stage:
01    Sbu
02   50A
03   UPS
04   Sds
05   USE
06   LFE
07   LFd
09   50Hz
11   2A     - don't want utility to charge too much.
12   45V
13   50V
16   CSO
23   byE
26   56.4V
27   54.0V
28   PAL
29   45V
30   All
31   Sbe
We are only 2 in the house and the Stove, Washing Machine, Tumble dryer are not connected to inverters. only the geyser which runs on a timer and only comes on mid morning and later in afternoon. (Trying to max the solar time).
Recently my second RCT packed up and I replaced it with the Mecer. Also upgraded both to firmware 72 40 U1.
Everything runs smooth, and then I get a code 80 error. (CAN). I shut everything down, start up and then it lasts for a day or so.
Can anyone help on setting suggestions and also on the error?
Hi Thinus
The changes I would make is Setting 12 47V or 48V below 48V is a SOC of below 50% your batteries will not last long under those circumstances. Again setting 13 is too low I would set this to 54 or 55V thus you can be sure that you batteries are receiving a decent amount of charge before going back to solar/battery.
Error 80 is a data/communication error check your cabling between the two inverters.
Thanks for the info. Is there any recommended monitoring system that I can easily install.
Would like to see at a glance the PV input, Load, battery capacity etc. Maybe something with its own screen. I know the Victron stuff don't match.
Yup. It shows the values reported by the various devices (ignoring calibration and efficiencies), updated about once a second at most (sometimes even less, CAN bus batteries often send data only every 2 or 3 seconds) so the values on the screen never adds up exactly :-)
