August 30, 20233 yr Hi Guys I have a 5KW Sunsynk inverter which has a dead LCD display. I can see faint blue LEDs light at the top. The inverter works, just the dead display. Any idees?
August 30, 20233 yr 11 minutes ago, Voltageza said: Hi Guys I have a 5KW Sunsynk inverter which has a dead LCD display. I can see faint blue LEDs light at the top. The inverter works, just the dead display. Any idees? Have you shut it down completely and tried the restart procedure? If that fails then get installer out to get you a new one / repair Else you could also use it without the screen with the App software (Solarman / Sunsynk / Solar Assistant)
August 30, 20233 yr Check if the display board receives 12 Volts from the power supply on the main board
