September 15, 20232 yr Good day I have a DEYE 5kW inverter and I am struggling to setup the work mode to export to the non essential load and not to grid. Could someone help with regards the correct settings.
September 15, 20232 yr Good day I have a DEYE 5kW inverter and I am struggling to setup the work mode to export to the non essential load and not to grid. Could someone help with regards the correct settings. Has the CT been fitted that would measure that no power is exported to the grid when you want it only to export to non-essentials?
September 16, 20232 yr Author Yes, it has, but I haven't confirmed if it is correctly installed. If someone would kindly send me some screen shots on the correct settings.
September 16, 20232 yr Yes, it has, but I haven't confirmed if it is correctly installed. If someone would kindly send me some screen shots on the correct settings. On the Deye 5kW it's as simple as selecting the mode: "Zero Export to CT." On the understanding that the CT coil is installed correctly.
September 17, 20232 yr Author Thanks, then something is not right as it does not work. I will check position of CT and direction.
