September 22, 20232 yr I am getting quotes for the installation and upgrading of 4 pylontech batteries. I'm overseas at the moment so can't do it myself. I've got quotes ranging from R2k to R5k. What is the "going" rate? Installers, please advise what is reasonable.
September 22, 20232 yr How do they justify R2k for just plugging a battery? No wiring is needed and the jumper cable that link the batteries comes with the new batteries. It is just switch off, plug and plug and then switch on again. Which area are you? If you have someone at home with whatsApp, you can do a video call and tell them what to do. Did that with my tenant and she is not technical at all
September 22, 20232 yr Author They have to upgrade 8 batteries and then add 4 type "C"....My usual solar electrician/troubleshooter, my wife,) is not keen.😆
September 22, 20232 yr How do they justify R2k for just plugging a battery? No wiring is needed and the jumper cable that link the batteries comes with the new batteries. It is just switch off, plug and plug and then switch on again. Which area are you? If you have someone at home with whatsApp, you can do a video call and tell them what to do. Did that with my tenant and she is not technical at all I have heard of R1200 per call out for gate/garage motors 🤔 Distance a major factor if not around the block. Edited September 22, 20232 yr by Scorp007
