Voltronic to seplos BMS
Hi all. I have 3 voltronic axpert 7.2kW inverters. All working very well. However, I am struggling to connect the coms to a seplos BMS. Does anyone have a pin out for both units?
There is lots of iterations of this online, and I just want to see if it’s worth doing or if I should just leave my Solar Assistant to control everything (as it does now)
If you are able to set baudrate of your inverter's bms connection to 19200, i'd suggest to stay with one of the newer seplos firmwares (e.g. CAN1101[V16.06.05_PN01_230916_SP80] ).
