October 19, 20232 yr I've got 2 Jet-air aircons that work great with the JASA app, full functionality incl a "mute" fan speed mode that isn't on the IR remote. Have read on here that to pull these into HA I need to first link them to the Tuya app, which I did - also appear to have full functionality on there. Then used the Tuya integration to pull the devices and their entities into HA using the Tuya IoT platform. Now when I access the climate entity for the one aircon I can either get a thermostat card or an entity card that opens the same thermostat but with different features, which is weird. Problem is firstly that the fan speed setting does nothing in HA (works in Tuya app). Second problem is that the two aircons, that are identical AFAIK, unless they have diff firmware, don't pull through the same features. So the one has a feature in HA called "swing_mode" that only shows up in its yaml code and not the other unit's. This is the swing feature that both units do have on their remotes and in the Tuya and JASA apps. I've just included screenshots of the one unit's code for now, just want to get fan speed selection working first. I went into the Tuya IoT platform to see what I could see but I'm lost, screenshots for reference. The IoT platform "send instructions" feature did work, for fan speeds as well. Any ideas welcome!
October 20, 20232 yr This has been a known issue on that integration for sometime. I have the same aircons and use the same integration to bring them into HA and have the same results - for over 2 years now. Haven't had the time / inclination to log a bug around this but perhaps together we can try this?
October 20, 20232 yr Author 17 minutes ago, mzezman said: This has been a known issue on that integration for sometime. I have the same aircons and use the same integration to bring them into HA and have the same results - for over 2 years now. Haven't had the time / inclination to log a bug around this but perhaps together we can try this? Defos. Where does one log bugs? I'm still an HA noob.
October 20, 20232 yr Author Found a non cloud solution. https://github.com/home-assistant/core/issues/72109 Apparently this guy will add your appliance if you ask nicely. https://github.com/make-all/tuya-local
December 11, 20232 yr On 2023/10/20 at 1:03 AM, BobTheDinosaur said: I've got 2 Jet-air aircons that work great with the JASA app, full functionality incl a "mute" fan speed mode that isn't on the IR remote. Have read on here that to pull these into HA I need to first link them to the Tuya app, which I did - also appear to have full functionality on there. Then used the Tuya integration to pull the devices and their entities into HA using the Tuya IoT platform. Now when I access the climate entity for the one aircon I can either get a thermostat card or an entity card that opens the same thermostat but with different features, which is weird. Problem is firstly that the fan speed setting does nothing in HA (works in Tuya app). Second problem is that the two aircons, that are identical AFAIK, unless they have diff firmware, don't pull through the same features. So the one has a feature in HA called "swing_mode" that only shows up in its yaml code and not the other unit's. This is the swing feature that both units do have on their remotes and in the Tuya and JASA apps. I've just included screenshots of the one unit's code for now, just want to get fan speed selection working first. I went into the Tuya IoT platform to see what I could see but I'm lost, screenshots for reference. The IoT platform "send instructions" feature did work, for fan speeds as well. Any ideas welcome! Hi @BobTheDinosaur how did you link the JaSA Aircon to the tuya app ?
December 12, 20232 yr 9 hours ago, SeaSickMama said: Hi @BobTheDinosaur how did you link the JaSA Aircon to the tuya app ? the Jasa App is just a skinned version of the Tuya App so once you remove the aircons from the Jasa App you open the Tuya app then follow the same pairing method - the aircons will show up in Tuya / Smart Life
December 12, 20232 yr Author 10 hours ago, SeaSickMama said: Hi @BobTheDinosaur how did you link the JaSA Aircon to the tuya app ? You have to put the aircon into pairing mode, i think you press the "health" button on the IR remote 8 times, or 10 times, it beeps twice or so after you've done it correctly. Then you add the device in the tuya app using AP (access point) mode - that means you connect to a wifi hotspot that the aircon makes for the setup. the rest is automatic.
July 19, 20251 yr Author On 2023/10/20 at 1:03 AM, BobTheDinosaur said:I've got 2 Jet-air aircons that work great with the JASA app, full functionality incl a "mute" fan speed mode that isn't on the IR remote.Have read on here that to pull these into HA I need to first link them to the Tuya app, which I did - also appear to have full functionality on there.Then used the Tuya integration to pull the devices and their entities into HA using the Tuya IoT platform.Now when I access the climate entity for the one aircon I can either get a thermostat card or an entity card that opens the same thermostat but with different features, which is weird.Problem is firstly that the fan speed setting does nothing in HA (works in Tuya app).Second problem is that the two aircons, that are identical AFAIK, unless they have diff firmware, don't pull through the same features.So the one has a feature in HA called "swing_mode" that only shows up in its yaml code and not the other unit's. This is the swing feature that both units do have on their remotes and in the Tuya and JASA apps. I've just included screenshots of the one unit's code for now, just want to get fan speed selection working first.I went into the Tuya IoT platform to see what I could see but I'm lost, screenshots for reference. The IoT platform "send instructions" feature did work, for fan speeds as well.Any ideas welcome!PSA update, 2 years later.The JASA app became unavailable on Android for a while and I had to move my aircons onto the Smartlife app (Tuya clone). Functionality for one of my aircons was incomplete - couldn't control fan speed, couldn't select all operation modes (heating for instance).Tried out the HA integration called Tuya Local https://github.com/make-all/tuya-localFollowed instructions, made use of the Tuya developer platform during setup, everything was basically done for me by the Tuya Local integration.It detected the Jet-Air aircon as a "tesla airconditioner". Entity in HA for this aircon now has full functionality, like functions I had never seen before even. 5 stars Would recommend.
