October 20, 20232 yr Can somebody tell me if a 5kVa Sunsynk inverter settings can be changed to reflect the same SOC on thd inverter as on my 5,2kWh battery? The battery BMS indicates 100% SOC and then the inverter reading is 85%.
October 20, 20232 yr Sounds like you have a communication issue between inverter and battery. Check your LiBMS page on inverter to see if it shows you stuff like SOC and temperature ,if not your comms is not working and should be checked according to the battery manual.
